I have a hazy water problem in my 18 foot above ground pool, my PH alk and chloring are right on ATM... I used a liquid clarifier that I baught at the local pool store with no success...
I have alot of particals in my water due to a problem with my solar blanket, here is what happened...
I used to leave my solar blanket on the pool for a few days before I would take it off for my swim, there is allways water on the blanket comming from rain and pool water from previous instalation, my pool is installed under ALOT of trees especially evergreens, so all the particals from the trees would fall on the blanket and be swashed into my pool when I would remove the blanket... honestly the water looked like oatmeal
I decided to not put the solar blanket anymore, but my water is still hazy even after a initial treatment of the clarifier (700ml for 7126 gallons) and at least 3 weeks of normal filtering before the treatment....
what can I do to get my water sparkling clean as it was when I filled it up the first time with my well water ??
Thanks![]()
