Results 1 to 9 of 9
Thread: Hello
    Aug 2012
    Texas
    Default Hello
    New user here. Been reading here a lot over the years and the forum has helped me alot. Looking for advice on replacing my pump motor now. I will post in equipment section.
    Default Re: Hello
    Hi,
    Until Ben completes your registration, this is the only forum you can post question in--but once he completes it, he'll move your post to the equipment section where it belongs.
    Welcome to the forum!
    Aug 2012
    Texas
    Default Re: Hello
    What I have is a 2hp Hayward Northstar pump that will need a new motor. It seems oversized and is a energy hog. I can't find a variable speed motor that will work as a replacement but would like to get a 2 speed. I will probably keep my single speed timer and use a toggle switch for high when needed. Is there anything else I need to consider like flow to skimmers or priming on startup? just looking for advice or ideas, thanks.
    Default Re: Hello
    What size is your pool?
    Aug 2012
    Texas
    Default Re: Hello
    16k gallon. I submitted my pool chart, did it not go through? Thanks
    15x24 kidney 8K* gal AG concrete pool; Chlorine hand fed; Hayward pro grid cf48 DE filter; Hayward northstar 2hp 1 speed pump; 8 hrs; fountain or waterfall; Hth 5 way drops; well; summer: none; winter: none; ; PF:15
    Default Re: Hello
    Note the correction in your gallons!
    A 2 HP pump is way, way too big for your pool. You probably want something like this:
    http://www.a1poolparts.com/-strse-84...eed/Detail.bok
    You want the 1HP pump, and you'll want to leave it on low most of the time.
    Aug 2012
    Texas
    Default Re: Hello
    Sounds good, I am looking at just the motor replacement. I can get a AOSmith replacement 1hp 2speed with impeller for under $300 but cant find a variable speed bolt on that will work. BTW thats supposed to be a in ground on my pool chart. Many thanks.
    Default Re: Hello
    On an 8,000 gallon pool, you'd be better off with a 2 speed pump. The variable speed pumps are all max HP motors, that can be turned down fairly efficiently. But, the 2 speed 1HP is going to as efficient, or more efficient than 2.5HP variable speed, turned way, way down . . . and it's going to be a heck of a lot cheaper and more reliable. Texas doesn't have the lightning Florida does, but putting electronics at the end of an power run outdoors is just asking for problems.
    Aug 2012
    Texas
    Default Re: Hello
    Good point I've heard those vs control boards are expensive if you can get them. We can get zapped by lightning also. I'll get a 2speed. I think the skimmers will be ok with the lower flow at longer run times. Thanks again
