Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Thread: Pool a disaster after vacation
  1. #21
    Aug 2012
    Virginia
    Default Re: Pool a disaster after vacation
    I did get the K2006 through your Amazon link.
    So, to reduce the alkalinty I should use the method on your site with 'slow' aeration from uncovered pool?
    The new sand does seem to be slowly clearing things...hopefully if I get the Alkalinity down things will improve. I'm hoping not to have to use the floc again since I seem to be a very bad vacuumer - stirred everything back up.
    Using the best guess chart I see I should keep the chlorine about 10. That's where it was this morning after adding 4.5 gallons of bleach last night. I doubt I got it up to the 25 shock level yet. That's a lot of bleach One gallon raises about 2ppm in 30,000 gallon pool? I know I saw the number somewhere, but can't remember now.
    Thanks for your help.
    Chantel
    20x40 grecian 27K gal IG vinyl pool; skimmer tabs; eclipse sand filter; hayward ultraflow, 1.5 hp 1 speed pump; 10 - 24 hrs; ; strips - aqua-chem 6-way; pool store testing; orig truck, topped off w/ well; summer: ; winter: mesh; laptop; PF:4.4
  2. #22
    Quote Originally Posted by cbuchin View Post
    So, to reduce the alkalinity I should use the method on your site with 'slow' aeration from uncovered pool?
    Yes, just be careful to not let your pH go below 6.8 -- you MUST keep it a bit higher than the lowest point on your pH scale (6.8 on the K1000 or HTH 6-way; 7.0 on the K2006). Otherwise you risk going into the 'below' zone, as in "6.8 or below". Having your pool at 6.0 or an extended period might damage your liner; having it at 5.0 is very likely to do so.
    Good. You'll mostly have to filter the precipitated calcium carbonate out.
    I'm hoping not to have to use the floc again since I seem to be a very bad vacuum-er - stirred everything back up.
    It's a learned skill . . . and one I'm beginning to realize not everyone has learned.
    Your pools PF is 4.4 (see the signature data). This means 1 lb of 100% stabilizer will add 4.4 ppm CYA to your pool (if it dissolved fully!). It also means that 1 lb of dichlor -- 55% available chlorine -- will add about 2.4 ppm FC to your pool => 4.4 x 0.55.
    One gallon of 6% bleach has about 1/2 lb of chlorine gas equivalent in it, so => 4.4 x 0.5 = 2.2 ppm FC
  1. Vacation pool
    By donfranko in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-07-2012, 05:21 PM
  2. Well water disaster
    By zipsman03 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-08-2011, 03:13 PM
  3. Now WHAT?!!! Pool Disaster
    By Trimom in forum Above-Ground Pool Construction & Repair
    Last Post: 05-04-2007, 11:46 AM
  4. Liner disaster
    By joing in forum Above-Ground Pool Construction & Repair
    Last Post: 07-22-2006, 04:54 PM
  5. Conversion - Baquacil to Chlorine - Disaster!!!!
    By jmaj43 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-12-2006, 01:19 AM
