Your TA is too high. Directions for lowering it: Lowering Alkalinity Step-by-Step
Also, please read: Using Muriatic Acid Safely
I wouldn't use any cal-hypo in your pool as your source of chlorine. Stick with bleach.
You didn't post a CYA reading above. Did you run that test?
