Results 1 to 10 of 12
Thread: New Member & New Pool Owner
    Aug 2012
    Manteca, CA
    Default Re: New Member & New Pool Owner
    1) Yes the filter pressure is rising when the pump runs. It goes up to about 23 psi, since the whole thing is new to me I don't know what the pressure was when the filter was newly cleaned consequently I don't know if the pressure has gone up the 10 psi or so that would indicate a cleaning is needed.
    2) I don't really have the capability to vacum the bottom. I do have a polaris 360/280? that sweeps the bottom but from what I've seen this is designed to pick up leaves and other debris not fine particles. I have been brushing the sides and pushing it towards the filter pick up at the bottom of the pool and this seems tp help, but in the morning there is always a layer of brown dust/particles on the steps, I do have the ability to run the polaris and the filter at the same time and that might explain why the bottom of the pool seems clean but the steps are not. I'll try to post some pictures. Before I purchased the house I had a pool inspection done and everything was at least functioning, BUt the inspector could not verify if the filter was actually filtering. The pool inspector was very impressed/stunned by the amount of pvc plumbing and valves the previous owner had installed. With that in mind I have not figured out to actually get water up to solar heater on the roof yet. :-)
    11x32 rectangle 8K* gal IG concrete pool; Bleach; American Products DE filter; 1 speed pump; 12 -16 hrs; solar heat; HTH 6 Way test kit ( from Walmart); utility water; summer: none; winter: none; Wireless network & a laptop; PF:15
    If you have the HTH 6-way DROPS test kit -- not 'guess-strips'! -- post complete test results.
    Also, you need a manual vac system -- everyone does. Do you have a working skimmer?
    Aug 2012
    Manteca, CA
    Using the HTH drop tests...
    Ph = 7.5
    Clorine = 5-10 ppm
    Alkalinuity = 70 ppm
    The only chemicals I use are Bleach, Borax and Baking Soda.
    What are your calcium hardness and stabilizer levels? Those are also in the HTH 6-way. (Well, actually, it's total hardness in the HTH, but close enough.)
    Aug 2012
    Manteca, CA
    Todays test results...
    Ph = 7.5
    Alkalinity = 80 ppm
    Clorine = 3-6 ppm
    cya = 50 ppm
    Hardness = 600 ppm
    Aug 2012
    Manteca, CA
    Today's readings...
    Clorine = 2-4
    Ph = 7.5
    Alkalinity = 70ppm
    I still can't get rid of the brown dust. I was looking at some of the battery operated sweepers but form what i've seen these just pick up leaves. Do any of these have the capability to filter fine particles out of the water?
    Quote Originally Posted by Green&Slippery View Post
    You need a manual vacuum, not a battery operated on.
    It's also possible that your DE filter is 'leaking' DE. If you touch the "brown dust" and it has some texture, it's DE. If it's fluffy, and you can't feel it, it's dead algae.
