Results 1 to 10 of 12
Thread: New Member & New Pool Owner
    Aug 2012
    Manteca, CA
    Default Re: New Member & New Pool Owner
    Using the HTH drop tests...
    Ph = 7.5
    Clorine = 5-10 ppm
    Alkalinuity = 70 ppm
    The only chemicals I use are Bleach, Borax and Baking Soda.
    11x32 rectangle 8K* gal IG concrete pool; Bleach; American Products DE filter; 1 speed pump; 12 -16 hrs; solar heat; HTH 6 Way test kit ( from Walmart); utility water; summer: none; winter: none; Wireless network & a laptop; PF:15
    What are your calcium hardness and stabilizer levels? Those are also in the HTH 6-way. (Well, actually, it's total hardness in the HTH, but close enough.)
    Aug 2012
    Manteca, CA
    Todays test results...
    Ph = 7.5
    Alkalinity = 80 ppm
    Clorine = 3-6 ppm
    cya = 50 ppm
    Hardness = 600 ppm
    Aug 2012
    Manteca, CA
    Today's readings...
    Clorine = 2-4
    Ph = 7.5
    Alkalinity = 70ppm
    I still can't get rid of the brown dust. I was looking at some of the battery operated sweepers but form what i've seen these just pick up leaves. Do any of these have the capability to filter fine particles out of the water?
    Quote Originally Posted by Green&Slippery View Post
    Also, you need a manual vac system -- everyone does. Do you have a working skimmer?
    You need a manual vacuum, not a battery operated on.
    It's also possible that your DE filter is 'leaking' DE. If you touch the "brown dust" and it has some texture, it's DE. If it's fluffy, and you can't feel it, it's dead algae.
    Aug 2012
    Manteca, CA
    That's something I never though of, and after touching it, it feels like DE. Thanks I think that might be the problem.
    Glad I could help!
