Thread: New member-Algae stain removal tips?
    Aug 2012
    So. Calif.
    Default New member-Algae stain removal tips?
    Hello. I think I've killed off the mustard algae that blossomed in my pool, but there are yellow stains in the plaster in the shadow side of the pool that I cannot brush off. Any tips for cutting the stains? Thanks
    Default Re: New member-Algae stain removal tips?
    Yellow stains where mustard algae was . . . are usually more mustard algae. If you have porous or old plaster, the 'stains' are probably live algae living out of reach of your brush.
    You can check by swimming down with a mask, and taking a look.
    Aug 2012
    So. Calif.
    Thanks Ben.
    I see new "stains" in areas where none existed yesterday, so I've got more reading and work to do!
    2 things will help you:
    1. Read the "Best Guess" page, linked in my blue signature bar -- stabilizer level is frequently an issue when mustard algae appears.
    2. Get a test kit so you can get sufficiently accurate readings of your chlorine and stabilizer levels. (Links below)
    And, 1 thing will help us help you:
    Pool Chart Entry Form
    Ben
    + Get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with, especially if it's a well, and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    + Having a good test kit makes pool care easier for EVERYONE, but is an ESSENTIAL tool for pools with problems. A good test kit means a kit that can test chlorine from 0 - 25 ppm, pH, alkalinity, calcium hardness, and stabilizer with reasonable accuracy. Test strips (AKA 'guess-strips' ) do NOT meet this standard. Some pool store testing is accurate; most is not. The ONLY way you'll know whether your pool store is accurate or bogus, is by testing accurately your own self. On the other hand, pool store 'computer' dosing recommendations are NEVER trustworthy -- ignore them. They are designed to sell more chemicals than you need, and WILL cause many pool problems.
    + We recommend the Taylor K-2006 test kit, which meets the requirements above, for many reasons. The HTH 6-way drops kit is a great starter kit, and is compatible with the K2006 (it's made by Taylor). There are a few alternatives; for example Lamotte makes an FAS-DPD kit that's OK -- but it costs 3x as much. But, we're not aware of any test that is better, and since we are all familiar with the K-2006 (and can help you with it) we recommend it exclusively ( Test kit info page )
    One caution for the 2012 season: Amazon does not stock the kits directly. So when buying at Amazon, Amato is our current preferred seller. However, they often don't list enough stock to last the whole day, so try order mid-morning. You should expect a delivered cost under $60 for the K2006A and under $95 for the K2006C. If you can't find that, wait a day.
    + Here are links to the kits we recommend (you can check local availability on the HTH kit, using the Walmart link):
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
