Results 1 to 9 of 9
Thread: Howdy! -- managing a commercial pool & spa
    Islandtime is offline Commercial pool users, operators, owners Islandtime 0
    Aug 2012
    North Georgia
    Default Re: Howdy! -- managing a commercial pool & spa
    First question..will my ColorQ be sufficient?
    The first day after a big weekend..
    Spa
    FC 10
    pH 6.8
    ALK 39
    CH 62
    CYA 14
    I dumped in approx 16oz sodium bicarbonate.
    I don't have any fears of recovering the spa. We just had a tremdous overload over the weekend with an outrageous splashout and refill. FC 10 is resulting from a puck; tomorrow I'll go back to bleach.
    The pool's bothering me.
    FC 6.75
    TC 7.52
    pH 7
    ALK 113
    CH 128
    CYA 125+
    I used approx 3 pounds generic dichlor shock. I believe we can either dump the pool or wait a couple of weeks and it'll be to cold to swim.
    My problem is that I say dump the pool. Even the pool store says dump the pool. But the trusted pool contractor says to wait it out and CYA will decline.
    + You need to switch to bleach. Period.
    + You need to maintain OTO DARK yellow (ie FC > 10 ppm)
    + You need to re-test your CYA using a 1:1 dilution with distilled water.
    + And, no, your ColorQ will not be sufficient, because it cannot measure chlorine levels above 10, which is something you have to do IF you want to run the pool well AND plan to have CYA levels above 40 ppm.
    + Your CYA levels *will* decline once the pool gets winter-slimed. It will NOT decline if you maintain a clear water chlorinated pool all winter. CYA is rapidly bio-degraded by a variety of bacteria that apparently typically make up a component of winter pool slime. The problem is, the end point of this process can be one of three things: nitrogen gas, nitrates (algae fertilizer), or ammonia. If it's ammonia, you will have a nightmare start-up next spring, unless you drain and refill.
  1. Commercial Pool --- Multiple problems/questions
    By xJustin in forum Commercial Pool Users, Managers & Workers
    Last Post: 05-12-2012, 02:05 PM
  2. Commercial pool help
    By jjk90 in forum Commercial Pool Users, Managers & Workers
    Last Post: 06-20-2011, 07:53 AM
  3. Managing water balance & high CYA
    By Jb1976 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-10-2011, 02:50 PM
  4. Managing the solar cover - our solution
    By AnnaK in forum Above-Ground Pool Construction & Repair
    Last Post: 08-23-2006, 07:28 PM
  5. Commercial/Public Pool expectations
    By drumr in forum Commercial Pool Users, Managers & Workers
    Last Post: 07-01-2006, 04:22 PM
