Results 1 to 10 of 12
Thread: New member with a new responsiblity..
    Default Re: New member with a new responsiblity..
    Trichlor tabs would be ideal right now -- they add chlorine; add stabilizer, and lower the pH! You can just add them to your skimmer, till you're able to maintain your FC that way. The only caution: if you use a pump timer, the chlorine level can get VERY high in the skimmer. Ideally, you'll run your pump 2x per day, to prevent that. OR, you can use floaters.
    Aug 2012
    Kentucky
    Thanks Ben.
    I was thinking that would be the case. I was hoping I could at least get some use out of the leftovers. I don't use a timer right now, I have been running the pump 24/7 during the clean up process. I do plan to use one next spring.
    JnKY
    30' Round 24K* gal AG Vinyl Pool; 5.25% Bleach; Hayward IS210T Sand Filter; Hayward SP1580 1 speed pump; Utility Water; Taylor K-2006C Test Kit
