Hi y'all,
We got 4 inches of rain two nights ago so I am currently getting my pool chemistry back to perfect. We have been working to lower the Ca++ for several months (currently at an almost reasonable 320 ppm, down from the crazy high 420 ppm of two months ago), so as the rain came down we pumped water from the bottom drains to keep from overflowing. This helped lose calcium, but of course it also dropped other stuff!
As of last night our readings were: FC 2.0; CC 0; pH 7.5; TA 55; Ca++ 320 and Cya 52.
I added cyanuric acid this morning (4lbs), and boosted the chlorine generator to 100% output to get the Cl- up. I am about to go out and test everything to see where I stand now. I am expecting that I will need to increase TA, and probably pH.
I have two questions:
1. What order should I add the new stuff? I know I read on here somewhere that certain chems should not be added too close together or you get precipitation, but I can't find that thread right now.
2. If I need to raise the pH how do I determine how much borax to use? (I haven't used borax before, since I haven't had the pH go low since I've been using the BBB method).
Thanks!
Alison
