Thread: Chlorine wont stabilize
    Aug 2012
    Oklahoma
    Default Chlorine wont stabilize
    Hello to all, ive been trying to get my chlorine to stabilize with no success yet. I have added 4 lbs of stabilzer, inn two pound intervals around 3 weeks ago and still my chlorine drops to zero reading with 36 hours. I bring the chlorine back up to acceptable ranges and within 36 hours its gone again. I have tested everything but the CYA levels, Ph is 7.2, Alkaline is around 120-130...not sure what the issue is. I know I need a test for my CYA but surely if it does not burn off, 4 lbs should have stabilized it..right?
    Default Re: Chlorine wont stabilize
    We'll need more information to be able to help. Please put your pool's info into our pool chart. Also, tell us exactly what all you have added to the pool, meaning ingredients and not product names like "shock."
    Pool Chart Entry Form
    Welcome to the Pool Forum!
    Quote Originally Posted by tlindsey18 View Post
    And there you have it!
    You need to KNOW the CYA level to know how high you need to keep the chlorine and how high you need to shock if there is a problem,
    Also, do you have any combined chlorine (or are you only testing for total chlorine with an OTO test kit?)
    My suspension is that you do have CYA. However, there is no way of knowing if it is too little, too much, or just right and there is another problem going on.
    Depending on the initial free chlorine level, the type of chlorine being used (stabilized vs. unstabilized0 and the amount of use and sunlight the pool gets this could just be normal chlorine loss or might indicate a problem.
    As Watermom said, we need more info about your pool, your testing method, and the poducts you are using.
    Aug 2012
    Oklahoma
    ok..
    i did the pool chart before, not sure what happened to it....anyway I completed it again. I am using liquid bleach (6%), muratic acid, when needed, and Borax. I have added 4 lbs of stabilizer from Home Depot (straight sanitizer) and then the liquid bleach every other day. Other than that nothing has been added, no triclor tablets or anything...
  1. Pool is cloudy and PH / Chlorine wont come up!!
    By dxdodger in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-10-2013, 12:57 PM
  2. Pool wont register chlorine.
    By NJpool22 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2012, 09:46 PM
  3. Cloudy pool that wont hold Chlorine.
    By bstevensa in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-02-2011, 09:37 AM
  4. How to stabilize my PH
    By ljt014 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2011, 08:17 PM
