Re: New Member: Variable Speed Pool Pump
For new pools, I will usually recommend a VS pump because the incremental cost is small in comparison to the cost of the pool so it is usually worth it, especially if you are planning any water features, spa or solar. A two speed pump can be more cost effective than a VS pump because of the lower up front cost but the extra flexibility of the VS usually makes the extra cost worth it.
