Results 1 to 3 of 3
Thread: Closing a.g. Pool
    Aug 2012
    St. Louis, MO
    Default Closing a.g. Pool
    I live in mo. And i want to close my ag pool, i use bleach, what do i need to add to the pool to close it and i do cover it for the winter
    Aug 2012
    St. Louis, MO
    Default pool closing tomorrow
    can i just put in 2 gal. of bleach and cover my pool with out adding any thing else, the cya is at zerro but everything else is ok
    Default Re: pool closing tomorrow
    Hey Willis;
    One of our team members kinda slipped up a little in how he phrased things, but unfortunately, he was basically correct in what he said.
    There's really no way for us to help you, with no more information than you've provided.
    If you had filled out the Pool Chart, and had a valid test kit, and we had valid test results from you . . . then we might could answer your question. But we've learned the hard way that when people say "everything else is OK" that translates to something like, "I've used 'guess-strips' and the numbers seem to be in the range that the bottle indicates is OK".
    On a well buffered pool (high borate level) with low alkalinity and calcium, NO algae what ever, CYA < 40 ppm, and about 5,000 gallons of whatever, about to be covered with an waterproof cover . . . 2 gallons of bleach might be an adequate closing dose.
    Otherwise, not so much. So, we really can't tell you what would be best tomorrow.
    Sorry.
  1. closing AG pool
    By UNITY520 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-05-2012, 05:29 PM
  2. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  3. Closing Pool the BBB way
    By DavidP77 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-21-2007, 10:26 PM
  4. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 10:50 PM
  5. Closing pool
    By bryjen in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-19-2006, 10:24 AM
