Results 1 to 8 of 8
Thread: IG pool closing questions
    Default Re: IG pool closing questions
    Blow out the main drain line w/ a compressor (or possible a shop vac) and close the valve to the drain, air-locking it. If you don't have a valve to isolate the main drain then, uh, I dunno what to do.
    Here is a plug with an air valve if that would help; never saw it before but I just googled it http://www.poolweb.com/Home/Other-Pr...h-1-3-4-Washer
    Other suggestions http://lmgtfy.com/?q=pool+air+lock+main+drain
    Jul 2012
    NY
    I just closed my pool with 2 main drains. The main drains were the last I closed....... for no other reason other than I thought they were going to give me problems. I blew out the lines until I saw the air bubbles gurgling at the surface...... then waited a few minutes at which point I "air locked" the mains by closing the main drain control valve. As I understand, this "air lock" will prevent the water from filling the pipe provided there are no pipe/valve leaks.
    I feel confident with my pool closing in that I've spoken with friends and co-workers who close their own pools and state they can't even get their mains to gurgle, they just hope they pushed the water in the pipe down below the freeze line, then air lock.
    18x38 free-form 24K gal IG vinyl pool; trichlor; jandy DEL DE filter; jandy 1 speed pump; 8 hrs; heat pump, mineral being eliminated; currently test strips.; utility water; summer: none; winter: vinyl / water bags; none; PF:5
