Filtration is what's going to remove the cloudy. Is your filter pressure rising?
With 0 CYA, you are going to lose alot of chlorine to sunlight - cloudy or not.
Well, I think I have the algae beaten. It only dropped 1ppm for 2 nights. However, now we have Hurricane Sandy and I had to turn the pump off during this storm. I foresee it being off for at least 3 days. Last I checked (yesterday morning) the FC was at 17 and pH was at 7.7. Any suggestions on what I should expect or will probably need to do after the rain? Also, while it's raining I was reading up on increasing CYA and getting what I needed to do that and was a little overwhelmed with what I was reading here. Do I need to wait for my pool to be clear or just the algae beaten (but water still cloudy) to increase the CYA? Also, the small jar at the pool store was $$$$. It was $20 for 5 lbs! Is there a source/brand that you recommend? Thank you for your advice. It's been a tremendous help!
membership updated.
Maintaining adequate chlorine (> 2.0 ppm where CYA = 0) should prevent the algae from regrowing. You can do this with 6% plain household bleach. Note that chlorine levels will drop RAPIDLY, once post-storm clear skies arrive, so add daily bleach doses late in the evening to allow them to work all night before being destroyed by sunlight.
Last edited by Watermom; 10-30-2012 at 01:50 PM. Reason: change post "store" to post "storm"
PoolDoc / Ben
well, not sure what to do. We are currently without power and isn't anticipated to be back on until Monday. I checked the chlorine level this morning and the FC was 1, CC was .4 and pH was 7.3. Is it ok to walk along the edge of the pool and dump some bleach in, if it's not being circulated? On a positive not, the dead algae settled and I can see the bottom and the water is clear. So when we get power back I can give it a good vacuum to waste. Just trying to figure out what to do until we can get our pump running again. Thank you again for the suggestions.
If you haven't already figured it out, yes, you can pour bleach in around the edges, and stir the water with your brush/broom.
15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
