Thread: Best Way to Winterize Filter/Valve
    Nov 2012
    NE Ohio
    Default Best Way to Winterize Filter/Valve
    I have a Tagelus sand filter with a Pentair Hi-Flow valve. I followed the manual's instructions precisely to winterize the unit. This invlovled depressing the spring and rotating the valve handle to the 'WINTERIZE' position on a rib. It states that this will keep pressure off of the main seal during the winter season.
    However, my local pool expert advised that it would be better to leave the valve in a typical position (non-winterized) to avoid wear on the valve's spring.
    My question is, which is better and does anyone have experience winterizing with this particular valve? Should the spring indeed wear out, is it easy to just replace the part out without replacing the entire valve? I just purchased my home and I found and old valve left in the basement and the spring was indeed worn.
    Default Re: Best Way to Winterize Filter/Valve
    NE Ohio?
    Better do what the manual says, unless your pool gear is in a heated area. 'Normal' positions of multiport valves usually trap a small amount of water inside the valve.
  1. Waterco F600 top mount multiport valve sand filter - removing the valve
    By wojie24 in forum Pool Equipment & Operations
    Last Post: 10-29-2011, 11:41 PM
  2. Hayward DE filter valve.
    By mborner in forum Pool Equipment & Operations
    Last Post: 10-18-2009, 01:48 PM
  3. How Do I Winterize My Sand Filter?
    By bsbrega in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-14-2006, 11:33 PM
  4. How Do I Winterize My Sand Filter?
    By bsbrega in forum Above-Ground Pool Construction & Repair
    Last Post: 09-02-2006, 04:21 PM
  5. Replacing old DE filter valve
    By jneil in forum In-Ground Pool Construction and Repair
    Last Post: 03-26-2006, 10:42 AM
