Results 11 to 16 of 16
Thread: Sam's Wholesale Chlorine
    Mahwah, NJ, USA.
    Default Re: Sam's Wholesale Chlorine
    Thanks. I'll search and hopefully find something nearby. Are those bears & Snow on your profile pic ? Need something sunnier I think
    NJ Pool: In Ground, 40,000 Gal vinyl liner, chlorinated using BBB, Gas Heated, DE Grid filtration.
    FL Pool: 10K gal gunite, chlorinated with 3'' pucks, cartridge filter, spill over spa
    Quote Originally Posted by donfranko View Post
    Lol! No, those are 3 Belgian Sheepdogs playing in the snow..relatives of our boy. They look bigger in the pic, but they are the size of Collies and look like black wolves.
    Quote Originally Posted by Lerronious View Post
    Being a chemist, I'm definitely on board with most everything advocated on BBB; I just can't get past this on point. And to be clear, I'm not trying to be a wise guy.
    BBB is an attitude; not a recipe. I've used bleach -- a LOT of bleach -- in servicing large commercial pools, but I've also used SWCGs, trichlor, dichlor and cal hypo. I've even used bromine (BCDMH), though that was under duress!
    Use the trichlor, if your CYA is not already too high.
    May 2013
    Concord,ca
    Can I use granulated cl in a bucket of water then pour it in? The reason I don't use a floater is because I have a fiberglass pool, so I use liquid. Just wondering
    You sort of have to pre-dissolve cal hypo; but usually dichlor dissolves fast enough so that's not an issue. If you have hodge-podge dichlor, I don't know -- it's possible that some of those blends are slow to dissolve.
  6. #16
    May 2013
    Concord,ca
    no that's good advice on mixing I can buy dry cal hypo and use it not mixing with liquid ch, just when I run out. I ws using a bottle of 12% a week but thanks to this site its been curtailed
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
