Results 11 to 16 of 16
Thread: Starting from scratch (new water)
    jilted is offline Registered+ Thread Analyst jilted 0
    Jun 2011
    Louisiana
    Default Re: Starting from scratch (new water)
    OK we are back in business as of yesterday evening and I am now circulating again.
    The water is clear but by yesterday evening i could feel the surface a tiny bit slimey so I brushed it before and after adding bleach to kick things off.
    I added:
    5 gal's of 6% bleach after the sun went down and this morning my reading was 10ppm (with last years reagents)
    15 bags of salt and my reading shows 3600ppm which is in line with my swcg recommended levels (have not run swcg yet)
    I'm almost done with adding 6 lbs of CYA but I need to do upwards of 12 lbs to get to the low end of my swcg recommended level
    So here's my test results from this morning:
    FC: 10
    CC: 0
    pH: 7.8
    Alkalinity: 160
    CYA: NA (new reagents on the way)
    Should I adjust anything from those initial readings or should I let it circulate somemore? It's only been mixing up the water for about 15 hours.
    Thanks!
    -stephen
    26,500g inground vinyl liner (new liner installed June 2013)
    Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
    Compu Pool CPSC36 SWCG - Polaris 380 cleaner
    Without knowing your CYA reading, it is hard to know if your chlorine is high enough to kill your impending algae bloom evidenced by the slimy feeling walls. Check the overnight chlorine consumption again tonight and see what that shows.
    Jun 2011
    Louisiana
    will do... I'm going to jump in later and feel the floor but the wall was not slimy.
    The FC test was approx 14 hours after dosing so I will check again this evening and again in the morning.
    the first 6 lbs of CYA has pretty much dissolved so I'm about to go add the 3rd 3lb container which should still have me at the lower end of my recommended level but since I am running pump 24/7 right now anyway I don't want to waste any time getting cya up to a respectable level
    Jun 2011
    Louisiana
    FC was 7.5 ppm last night and 7.0 ppm this morning. I haven't powered up the SWCG yet but I guess it's time. Salt test last night shows 3600 ppm. I was waiting to start it up to get an idea how fast the FC is burning off but ever since I added chems (2 days ago) it's been cloudy and cool here.
    I know I need to continue adding CYA but my salt calculation was 18 bags to get to 3500 ppm and I am at 3600 with 15 bags. I am still waiting on my new CYA reagent to test. I don't want to over stabilize!
    thanks
    -stephen
    Jun 2011
    Louisiana
    Just checking in. Water has been pretty good.
    FC has been easy to manage so far.
    Having trouble getting pH to level off I guess the SWCG is keeping it increasing. Also the alkalinity never drops when adjusting pH.
    Test today:
    FC: 5.5 ppm
    CYA: ~50 ppm
    pH: close to 8
    Alkalinity: 140 ppm
    I've dosed muriatic acid a few times according to the book in the taylor test kit. 2 drops bring the test in line. The ph does come down after this but rises again in a couple days. The alkalinity stays 140.
    I've been running my pump 18 hours a day which should be enough to circulate the whole pool twice. The SWCG was running at 100% but I have reduced it to 80% to see if thats enough to keep the FC stable.
    Any input on my pH/alkalinity situation?
    Thanks!
  6. #16
    BigDave's Avatar
    I'd target 7.0 - 7.2 for pH and try to keep it there until the TA is where you want it.
  1. Starting from scratch - leveling ground
    By tebbert in forum Above-Ground Pool Construction & Repair
    Last Post: 08-07-2012, 11:40 PM
  2. Starting from Scratch
    By anixon7 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-06-2012, 03:50 PM
  3. New Pool & Starting From Scratch!
    By tnt69 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-04-2012, 04:59 PM
  4. Determing water level in ground before starting
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 05-19-2006, 01:06 PM
