Results 1 to 10 of 13
Thread: Algae and cloudy pool..Someone pleeease help me!!! I NEED ASSISTANCE!
    Ontario.
    Default Re: Algae and cloudy pool..Someone pleeease help me!!! I NEED ASSISTANCE!
    After knocking out the obvious algae, your pool goes cloudy, and it will take more chlorine than you think to get it clear. Sometimes it goes to clear pretty quick, sometimes it takes several days to get there, but you need to keep the chlorine level up. Better to err on the side of more chlorine than to little. I pound it with 10-20ppm until the water is clear, then when the chlorine drops to a maintenance level, work on balance PH, TA and CYA.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
  1. Help....cloudy pool with stains and algae
    By mammatiger in forum Dealing with Algae & Slime
    Last Post: 06-27-2013, 10:23 AM
  2. Cloudy pool after killing algae
    By peyman84 in forum Dealing with Algae & Slime
    Last Post: 06-26-2013, 05:19 PM
  3. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  4. Help - major algae now cloudy pool
    By xoroniox in forum Dealing with Algae & Slime
    Last Post: 04-17-2006, 12:33 PM
