Results 11 to 18 of 18
Thread: 18ft Intex pool help with well water
    May 2013
    NJ
    Default Re: 18ft Intex pool help with well water
    1 HP pump -- even the funky-rated AG 1 HP pumps -- are almost certainly too big for that filter. Put a valve between the filter and the pump, and throttle the flow back when you are trying to remove the iron.
    Sand level inside the filter should be about 6" below the point where water enters the tank.
    Getting more sand Monday. it appear very low if spec is 6 inches
    sand was new last season can i reuse still?
    Putting in valve now as recommend.
    Installing all plumbing
    HAve a 6way test kit now, borax and muratic acid
    May 2013
    NJ
    Update.. I was thinking the water enters from the top of unit so my sand is low.. .After looking . does water come down the tree that is covered by sand?
    I got this filter used Making sure every thing is here..and looks good
    thanks so much B2R
    BigDave's Avatar
    Down through the sand on filter - up through the sand on backwash.
    May 2013
    NJ
    Then I need more sand. Measuring from top of opening to sand is about 12 inches
    May 2013
    NJ
    UPDATE
    I have the filter run for 48 hours pools pretty clear. Lots on bottom to vacuum..
    Six way test kit results
    cl br .5-1
    ph 7.5
    total alkalinity kinda looked black/purple
    cyanuric acid and total hardness not getting valid result . will try again if really needed
  6. #16
    CYA => clear result = 0 ppm CYA.
    Lot's of people think they are not getting a CYA result, when there's no cloudiness. But, they are -- they are just getting a "no CYA" result.
    Hardness test, with metals present, can be tricky. There are work-arounds, but you needn't bother.
  7. #17
    May 2013
    NJ
    what is my course of action? with theses results..
    Yes cya was clear .. lol
  8. #18
  1. Using a 5.5 kw hottub heater to heat a 18ft intex pool?
    By Mattiemo in forum Intex-type Pool Setup & Operations
    Last Post: 06-17-2013, 04:37 PM
  2. Intex 18ft 48 deep pool question on chemicals
    By Sin2001 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-19-2012, 10:10 PM
  3. got new 24x5 round intex pool need help with water. Sandy water..help
    By iwannaswim in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-08-2011, 09:42 PM
  4. What size pool cover to get for 18ft AG
    By nicole12 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-25-2006, 02:16 PM
