Thread: Moving and re-installing above-ground pool
    May 2013
    SE Kentucky
    Default Moving and re-installing above-ground pool
    I have been given an above ground pool. The pool has been drained but I have to disassemble it with help from friends. It is a 30 foot round pool and I'm hoping someone can tell me what tools I need to disassemble the pool. Thanks.
    I think it is a Sandy Point pool, it looks like this
    http://www.backyardcitypools.com/Ima...Round-Pool.jpg
    Default Re: Removing an above ground pool
    We've had this sort of question many times over the years. Currently none of my trusted posters have that sort of specific AG pool knowledge -- and I don't, either. (My personal experience is mostly with very large commercial pools.)
    I can tell you that, in the cases where we've heard back from the posters, things haven't gone well.
    Think of if this way: if you don't currently have the knowledge to disassemble the pool, it is (unfortunately) rather unlikely you'll be able to reassemble it successfully. At the least, liners rarely survive the move.
    I'm sure there have been exceptions who HAVE successfully disassembled, moved and reassembled an AG pool; I sincerely hope you become one of those.
    BigDave's Avatar
    Ben is, of course, right. Since you're warned, if you decide to proceed, I'll add that when you put it up you have to build it on level - measured level - NOT looks level undisturbed soil.
    Thanks Dave. The 'looks-level' vs. 'is-level' problem seems to trip up a lot of people.
    JGowens, if you decide NOT to take the offer, I'd encourage you to look at an Intex Ultra 18' or larger. You can get them for under $1,000, you can install it yourself, and they seem to last 3 - 6 years. That's a much easier and cheaper way to find out if your family will really enjoy a pool. And, Intex Ultra pools *can* be taken down and moved, fairly easily.
    (That's the Ultra pole, with the steel tubing frame, and NOT the Easy Set doughnut pools, which seem to fail pretty quickly.)
    Apr 2012
    Texas
    Been there, done that. Regarding disassembling & moving an existing pool. It was a disaster waiting to happen.
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
