The dosing plan covers EVERYTHING you should be doing to your pool when you start up, unless you have water with staining metals present (usually well water; rarely acidic tap water arriving via copper pipes).
PoolDoc / Ben
Thanks Doc.
When my chemicals come in should I dissolve in water before putting them in the pool as suggested by the Intex documentation or does the dichlor and borax dissolve quickly enough to apply directly?
