Thread: Pool girl
    May 2013
    Columbus,Ohio
    Default Pool girl
    I recently came back to the homestead when my father passed & my mom needed care. I have a L shaped pool. I just replaced the sand filter & new hayward pump. I would like to know what order should you add Chemicals? And they timing in between I just opened the pool on Memorial day and all my levels are low. The Ppm confuses me as well oh I am i central n Ohio
    It has been 80 low 90s the last 2 days here.
    Any advice welcome
    Anastasia
    Default Re: Pool girl
    An L-shaped in-ground is probably in excess of 25,000 gallons. If you'll dump 3 gallons of PLAIN 6% household bleach in the pool EVERY evening, that should hold you till you can work down the list below.
    1. Order a K2006 test kit (see below for link)
    2. Purchase a plain OTO/phenol red kit locally (yellow/red drops). Use it, and report results.
    3. Measure the pool:
    --> Length of each side of L
    --> Width of each L end
    --> Depth at each L end
    --> Location of deep end (short side; long side of L?) if there is one
    --> Depth of deep end, if any.
    4. Report this info, and we can work out a chemical plan
    5. Hire someone -- pool guy -- to show you how to operate the pool equipment. Ideally, have a 3rd person video as they show you.
    May 2013
    Columbus,Ohio
    I have an hth 5 way drop kit. Levels are CL 5 ph 6.5 alk 40. Cya 70. In the last 24 hours I added in order 3lbs baking soda, 4 lbs borax now 5 gallons bleach.
    + Read the Best Guess Chlorine page, linked in my signature
    + Hold your chlorine level in the DARK yellow range, till you have the K2006.
    + Unless your pool is concrete, do not add any more baking soda or calcium hardness.
    + Use borax (Walmart detergent section) to raise pH to 7.2 or so.
    May 2013
    Columbus,Ohio
    How much borax should I use? pH is 6.5 for a 35k gallon pool. Vinyl liner. I also have white foam in the skimmer & a lot of cloudy floaters. Should I scoop out the foam? I am also running my cleaning robot thanks for replying Pooldoc
    May 2013
    Columbus,Ohio
    Hey Ben I posted this somewhere else bc I couldn't find my way back but here goes
    I think I am having the same problem. I am new to the forum ( well posting anyways) I have a 35k+ gallon L shape boy cya is 65-70 and I can't keep the CL up I have used 45 gallons of cheap bleach in 3 days. Readings are CL drops from 5 to 0 overnight. Ph is going between 6.5 & 7.2 I have used 6 boxes borax in the last week also. I have 3" chlorinating tabs running constantly thru a chlorinator. Alk is 50. Using 6 way hth kit & strips. Strips say stabilizer is low but hth says high? Very confused. I am having surgery Wednesday & need to get this in order any help is appreciated.
    Hth 6 way
    CL 0 just added 5 gallons bleach tested its bright yellow after 1 hour
    Ph 7.2
    Alk 70
    Cya maybe 65 Can't test anymore I ran out of drops. ( the bottles is not proportionate)
    Thanks so much for having this forum I am going crazy & everybody is driving me crazy asking when it's going to be ready
