Thread: Phosphate level
    May 2013
    SW USA
    Default Phosphate level
    my store tells me the phosphate level is too high, can I add algicide to the water?
    Default Re: Phosphate level
    Welcome to The PoolForum!
    The phosphate level is irrelevant since the proper chlorine level can prevent algae growth regardless of phosphate level. If you don't have any visible algae or unusual chlorine demand right now, then just maintain your Free Chlorine (FC) level relative to your Cyanuric Acid (CYA) level according to Ben's Best Guess Guide to Swimming Pool Chlorine.
    You probably need to get a proper test kit -- the Taylor K-2006 is the best to get (NOT the K-2005) and you may need to order it online since most stores don't carry it.
  1. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  2. Pool store said my phosphate level is too high
    By debdevero in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-29-2008, 12:43 PM
  3. Phosphate confusion
    By aguaguy in forum Dealing with Algae & Slime
    Last Post: 08-23-2006, 08:22 PM
