Results 1 to 10 of 10
Thread: Loss of pressure when adding basic solar heater
    Jun 2013
    Canada
    Default Loss of pressure when adding basic solar heater
    We are new to owning a pool. We had a sailboat on the east coast of Canada and enjoyed it greatly when we actually sailed. It was very inconvenient to get to the boat, then there was a lot of work prepping, and if you forgot something it was an hour back to the house and an hour back to the marina. Weeknights were difficult to pull off so it was basically nice weekends.
    Now we open up a patio door and there's a pool off the deck. We think we are going to like it
    We have a 16' x 48" round above ground pool and that is all we think we really need. Although that is what I said about a 26' sailboat -lol, and that changed quickly.
    I hooked up a solar heater, just a cheapie, basically black tubing that lies on the ground. Trying to stay cheap until we learn if we will actually use a pool. When I attach the solar heater, the water pressure drops dramatically. The water that was coming into the pool was definitely warmer though and I could see it making a difference over time.
    I expected some drop, but the drop was a lot. The pump is 1500 gph, the hose is 1-1/2" for the pump to the pool. I have to reduce the hose to 1-1/4" where it attaches to the solar heater.
    I am going to install a bypass valve to keep the water pressure up and hope this works, unless there is a better suggestion. I am also not sure what size hose to use in the bypass, I was thinking 1-1/4", but maybe that doesn't matter.
    Thanks for any ideas, or for mentioning something of which I am not thinking.
    Scott
    mas985's Avatar
    Pleasanton, CA
    Default Re: Loss of pressure when adding basic solar heater
    If you are trying to force all of the water through a small panel, that could be your problem. The extra head loss in the panel can reduce flow rates significantly. Your best best is put in a bypass and adjust it so that the filter pressure does not go up by more than a few PSI when solar is engaged.
    Mark
    Add to what Mark said, the fact that most "1500 gph" pumps are low pressure devices with very little reserve capability.
    You may need a standard AG pool pump, to drive the water through the panels.
    BigDave's Avatar
    My two cents, sorry to be contrary:
    If you find flow is inadequate for filtration with the solar panels on and you'd like to get maximum heating from the panels, plumb a bypass around the panels and run all the water the pump can move through the panels when the sun shines and bypass the panels - pumping only through the filter when it's dark.
    mas985's Avatar
    Pleasanton, CA
    Higher flow rates do equate to higher thermal transfer efficiency but only up to a point. Most manufactures recommend 0.1 GPM/sq-ft of panel to obtain maximum efficiency and forcing more water than that through the panels won't get much more heat into the pool but it will lower the electrical efficiency of the pump. For most panel setups, optimum efficiency is achieved at a point that is 3-5 PSI above the operating point without the solar panels.
    Mark
  1. Replacing Solar thermal and natural gas with Solar PV and electric pool heater
    By California Newbie in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 08:14 PM
  2. Heater help needed - gas pressure
    By Geeper in forum Pool Equipment & Operations
    Last Post: 11-25-2010, 02:25 AM
  3. low pressure when adding DE.
    By Amir in forum Pool Equipment & Operations
    Last Post: 05-24-2009, 06:10 PM
  4. loss of pressure !?!?!
    By bsbrega in forum Above-Ground Pool Construction & Repair
    Last Post: 06-20-2006, 08:27 AM
