Re: First test readings of season
No headway at all here, tomorrow morning will be my 48 hr mark but its showing no signs of a slow settle. Tomorrow afternoon I will probably start a partial drain and refill, I am also going to install a valve between pump and filter and see if I can slow my water flow. Want to also check my sand again, I'm not convinced the sand I put in new is big enough, it seemed really fine
