Thread: Total Alkalinity at 150
    Jun 2013
    TX
    Default Total Alkalinity at 150
    My total alkalinity is at 150. How do I lower that? I emptied (mostly) my pool this past winter and refilled it after doing a little inspection.
    My CYA couldn't be measured because it was lower than 30.
    My TC is basically 0, which makes sense with the CYA being so low.
    I have 2 gallons of bleach-8.25% to put into it tonight and I'll be purchasing some stabilizer, and more bleach, tomorrow. Luckily the water is still clear.
    Jun 2013
    TX
    Default Re: Total Alkalinity at 150
    I forgot to mention that my pH is 8.2, so adding muriatic acid should help with TA, right? Never mind, I should have read your previous answer first. Thanks for the info!
    Last edited by Chuckles76; 06-04-2013 at 01:18 PM. Reason: I didn't read the previous answer first. Yes, i'm an idiot.
    Jun 2013
    TX
    Your pH is probably 8.2 or HIGHER, not 8.2 . . . unless you are using a pH meter.
    Yes, lowering the pH will lower the alkalinity.
    Aight, thanks.
    Is your pool vinyl? If so, higher alkalinity is not a problem unless your pH is continuously rising.
