Thread: Total Alkalinity at 150
    Jun 2013
    TX
    Default Re: Total Alkalinity at 150
    Your pH is probably 8.2 or HIGHER, not 8.2 . . . unless you are using a pH meter.
    Yes, lowering the pH will lower the alkalinity.
    Aight, thanks.
    Is your pool vinyl? If so, higher alkalinity is not a problem unless your pH is continuously rising.
    Jun 2013
    TX
    No it's gunite. I finally got some trichlor tabs and stabilizer to get this pool under control. Now I'm watching the chlorine and pH. I really appreciate all of the info from y'all. It's very motivating.
