you can goop Magic Lube on the thread, and see if it gets sucked into the pump.
Other things to check for:
=> skimmer weir stuck or vortexing . . . and sucking air
=> loose valve on suction line. (WHERE it would be loose, depends on the valve type.)
PoolDoc / Ben
