Results 1 to 10 of 10
Thread: Water gets cloudy for unknown reasons - frustrated!!!
    Default Water gets cloudy for unknown reasons - frustrated!!!
    I'm totally frustrated and nearly ready to give up on my pool. Even though I maintain my CL by using liquid (12.5%), the water gets cloudy from perfectly clear way too frequently. I'm now on my second round of cloudy water in two weeks.
    My last bout a week ago with cloudy water, I shocked with liquid, holding FC around 15ppm until the water was super clear and the pool consumed no CL overnight. My CYA is 30, pH 7.5, TA 80. (I've really seen no or maybe a max of 1ppm of CC at any time.)
    This past weekend, while the water was clear I put new sand in my filter and inspected the laterals for cracks and found no issues. I replaced the seals on my multiport valve (it was leaking a little). The water stayed perfectly clear through the weekend.
    I tested the water yesterday morning and the FC was 5.5ppm and the water looked fine. I go out to test this morning and the FC is 2.5ppm (which I think is okay for my cya level) and I peak under the cover and can barely see the bottom.
    I'm smoking hot because now I'm going to have to keep the solar cover off, lose my heat and spend dollars shocking again! I'm ready to dump all the water and start over.
    Please help.
    Stats
    24K IG vinyl pool
    300 lb sta-rite sand filter
    1.5 HP pump
    CYA 30
    pH 7.5
    TA 80
    Testing with FAS-DPD
    Solar cover when not in use
    Water source is municipal
    BigDave's Avatar
    Default Re: Water gets cloudy for unknown reasons - frustrated!!!
    Did you find CC when you tested this morning? 2.5ppm FC is just below the Best Guess Chart minimum for CYA 30. Maybe it's the beginnings of a bloom?
    Big Dave,
    Unfortunately I didn't check the CC this morning and I've already added enough CL to bring it back to 15ppm.
    I know 2.5ppm is on the low side, but it could not have been there for long since it was 5.5ppm just 24 hours prior. It just seems like my water is over sensitive to becoming cloudy.
    I'm looking for any guesses.
    BigDave's Avatar
    Cloudy is something in the water, maybe precipitate, maybe algae. Since it goes away at shock FC, I'd guess algae. I'd expect some CC if it were algae - that's why I asked. Perhaps move the low target up a bit to 4ppm FC after this shock is complete? When you've shocked did you maintain shock level for a day after the finish line?
    Your pump is way over-sized for your pool. I wonder if because of that, you are not filtering things out well and instead just blowing everything through the filter back into your pool. This may not be it, but just thought I'd throw it out there.
    Watermom,
    Actually I made an error on the HP size. It's a 1HP motor, not 1.5HP. I don't really think that is too bad for a 300 lb sand filter, but what do I know.
    Big Dave, yes I held it high (1 day) after the water cleared and I did an overnight FC test to confirm that the CL was the same in the morning as it was the night before.
    Another idea I'm having about why the water got cloudy again--- When I shock my pool, I keep it uncovered so I don't kill the solar cover. My cloudiness came back two days after covering it again because the WX has gotten a little cooler. Wondering if I'm dragging contaminants back into the water from the cover? So this time I'm going to shock with the cover on. Not good for the cover, but I'm hoping that if contaminants on the cover are a problem, then I will kill those in the "shock" water.
