You may not be adding more chlorine, (and it doesn't sound like you need to) but you are running your pump and letting your filter do its job which is to remove stuff from the water. Thus, it is clearing. I would run it pretty much 24/7 while you are trying to clear it up. After that, you can cut your run time down. Glad to hear it is looking better!
