Thread: Want to build block pool myself someday
    Jun 2013
    Louisiana
    Default Want to build block pool myself someday
    Trying to get some "how to's" hashed out and learn along the way till I build.....I mean when the wife let's me dig a big hole in the yard.
    Anywho, I saw where a block pull is built and a liner track is installed below the water line with tile installed at the water line. Question is, can the track be installed watertite with construction adhesive and/or silicone? And if any water gets by the track and below the liner will it just drain out to the ground through a vermiculite bottom? The water table is well below the pool bottom at my location.
    Another question. Where can I read up on plumbing? I can size lines and pumps, but for a certain pool size/shape, I want to learn where to locate skimmers, drains, returns, etc.
    Thanks,
    Mike
    Default Re: Want to build block pool myself someday
    Hi, Mike, and welcome to the Pool Forum! I'm sorry I can't help you with these questions, but just wanted to pop in and say hi and let you know that you weren't being ignored! There may be someone here who can help with some of your questions, but I have to tell you, pool building is not the main focus of our forum; water chemistry is. Having said that, we will keep our fingers crossed that someone can offer you some advice. PoolDoc may be able to answer some of your questions since he is also a master plumber.
    Block pools were fairly common 25 years ago, but I've never seen any online how-to. Doesn't mean there isn't one, but I haven't seen it.
  1. Want to build my own pool
    By fta123 in forum In-Ground Pool Construction and Repair
    Last Post: 06-16-2011, 09:41 PM
  2. Photo resurrrection - 2005 - 2006 Concrete block pool
    By PoolDoc in forum Photo Gallery
    Last Post: 05-04-2011, 06:46 PM
  3. Waterproffing pvc pipe thru cinder block pool
    By rvg40 in forum In-Ground Pool Construction and Repair
    Last Post: 11-29-2010, 09:43 AM
  4. Concrete block pool wall
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2007, 08:52 AM
