Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
Thread: Old Pool to a New Owner
    Default Re: Old Pool to a New Owner
    you're welcome.
    Jun 2013
    Clearwater, FL
    Ok, I bought and put in 6 jugs (121 fl oz) of Great Value bleach: SODIUM HYPOCHLORITE 8.25% which says it yields 7.86% available chlorine.
    CYA tested at 48.
    I rinsed the filter and brushed the walls. The pump is running.
    BigDave's Avatar
    ... my cousin Bryan (who I went to first for help before here because he has "been in the biz for 20 years") made these comments ...
    People pay your cousin to work on their pools - Yikes!
    Mustard algae is hard to kill and will take a lot of time, perseverance, and chlorine. More chlorine than any strip can measure.
    Jun 2013
    Clearwater, FL
    I guess in his defense, since he's family, he builds pools...
    Many pretty decent pool builders know almost nothing about pool chemistry, though not all of them acknowledge that.
    Just saying . . .
  6. #16
    Jun 2013
    Clearwater, FL
    Yes, no further advice will be solicited from him.
    So what's my next step after the bleach and CYA being at 48?
    (BTW, I also added my phone and address for verification.)
  7. #17
    Jun 2013
    Clearwater, FL
    All I could get out of that customer service number from the WaterAce website was the pump is 3/4 HP. Is that helpful?
  8. #18
    Quote Originally Posted by TonyIsSocial View Post
    That info, plus the filter label, is enough to tell that the pump is not too large for the filter.
    Do this:
    1. record filter pressure with pump on -- is it always 30 psi as shown in the picture?
    2. turn the pump off -- read and record filter pressure. (should be zero if gauge is functioning)
    3. remove cartridge; reassemble filter; turn pump on and record pressure. Measure the LENGTH and DIAMETER of the cartridge as accurately as you can. ALSO, measure the INSIDE DIAMETER of the the center hole of the cartridge.
    4. turn pump off, replace cartridge (after cleaning if you like), turn pump on and record pressure.
    If the gauge is working, and the difference between #3 and #4 is more than 5 psi, you probably need a new cartridge.
    Here's what happens to the cartridges:
    1. When new, each folded pleat is separated by a small amount of space.
    2. BUT, the pleats can only support a few PSI *across* the surface of the filter material, before they collapse and touch each other. If the pressure WITHIN the filter tank, but OUTSIDE the cartridge becomes 10# or even 5# more than the pressure INSIDE the cartridge (in the center tube area), then the pleats COLLAPSE and press against each other.
    3. Once the pleats collapse, the effective surface area of the cartridge becomes as little as 10% (!) of the ORIGINAL surface area.
    4. If the time period of the collapse is brief AND if the pleats are not too close together already, the pleats may spring back when cleaned.
    5. BUT, if the collapse continues for a long period because the pump is too big, OR because the filter is run for a long period dirty, then the collapse becomes permanent, and the cartridge is essentially ruined.
    6. Use of very stiff 4oz REEMAY, instead of cheaper 3oz Asian knock-off REEMAY copy will resist this failure. Also, older cartridges, with more space between pleats, will resist collapse. Unicel and Filbur cartridges have 4oz genuine REEMAY. Pleatco and other brands usually use cheaper, lighter weight Asian fabrics.
    7. The pictures of your cartridge, while you were cleaning it, indicate that your cartridge is already destroyed -- and has a EFFECTIVE cartridge size that is 1/4 or less of the ORIGINAL size.
    8. Replacing it with a Unicel will likely reduce your problems with filtration, and will improve filter performance.
    9. BUT, you must be careful to clean the cartridge BEFORE you see a filter pressure rise of 8 psi.
    10. I'll need to help you select a Unicel cartridge -- it's hard to buy them, because Pleatco cartridges are cheaper AND higher margin for retailers, so they are sold MUCH more commonly.
  9. #19
    Jun 2013
    Clearwater, FL
    The pressure from #1 was 10psi. It's not always at 30, that was just when it was clogged with the algae.
    #2 pressure was 0psi
    There was only light algae/dirt on it at #3
    #4 pressure is at 3psi
    Outside diameter = 9"
    Inside diameter = 4"
    Length = 17.25"
  10. #20
    Looks like this is what you are looking for:
    Waterway Pro Clean 100 => Unicel C-8409
    Unicel specs are 8 15/16" OD; 17 3/8" long;
    The pressures you report are consistent with a collapsed filter. I'd recommend getting two cartridges and swapping them out whenever pressure climbs to 5 psi above initial. Once you get the cartridges, use this guide to cleaning them:
    Cleaning-your-Cartridge-Filter-wiithout-Damaging-It!
  1. New Pool Owner
    By HMSpool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2012, 10:32 PM
  2. New pool owner
    By Ameztoy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-27-2012, 09:06 PM
  3. New Pool Owner!
    By Kainoa in forum Pool Equipment & Operations
    Last Post: 11-13-2011, 09:35 PM
  4. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
  5. New Pool Owner
    By bobcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2010, 03:03 PM
