Thread: Gibraltar 16x24 pool
    Jun 2013
    new hampshire
    Default Gibraltar 16x24 pool
    HALP!!!
    Just installed the pool. but i'm not sure about the sand level.
    Does the sand level go about the metal frame (to cover the metal bolts on the frame)?
    I ask this because there are a bunch of bolts on the metal frame that stick up about a 1/4 of an inch and don't want them poking thru the liner.
    Default Re: Gibraltar 16x24 pool
    I am not a pool installer but I am going to email one of our support team members who is to see if he can reply. Not sure if he will be able or not since he is extemely busy this time of year, but will try.
    Welcome to the forum! By the way, do some reading about the chemistry as you start this new pool so you can start it out right. Let us know if we can help with that part of things.
    BigDave's Avatar
    Yep, you should have a couple inches of sand under the floor and a 6"x6"-8"x8" cove built up inside the base od the wall.
    Jun 2013
    new hampshire
    Thank you so much. its leveling time
  1. New Install of Used Gibraltar Pool
    By colleenbobrussell in forum Above-Ground Pool Construction & Repair
    Last Post: 05-10-2012, 12:15 AM
  2. gibraltar pool deck
    By ecorda in forum Above-Ground Pool Construction & Repair
    Last Post: 10-22-2011, 10:06 PM
  3. gibraltor pool setup for 16x24 infinity pool
    By auntiekeem in forum Above-Ground Pool Construction & Repair
    Last Post: 06-25-2011, 06:29 PM
  4. Gibraltar Genesis 16X24 Install Instructions
    By robin640 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-08-2006, 09:58 PM
