Ben:
The Post Office had a little mixup and my test kit only arrived today. In the interim, I added the minimum CYA and bleach for the recommendations of the pool calculator, and have been adding bleach here and there to keep the level up. Things have cleared up (pool looks good visually). Since startup, I've filtered 24/7, and have for the past week run a couple of round of acid & aeration (using my spa jets). I decided to do this, in an attempt to lower the total alkalinity, which showed 270 at the pool store (and has consistently shown over 300 with my old home test kit). I was away for the weekend, so this morning, I found the pH over 7.8 using my old kit, so I added a quart of MA.
After going to the post office this morning, and equipped with new TF-100 test kit in hand (I had ordered before you told me to order the K2006), I tested a few things at lunch and here's what we know today about my 22,500 gallon vinyl pool:
Free Chlorine - 3.5
Total Chlorine - 3.5
Cyanuric acid - 20
Total alkalinity - 380
pH - 7.5
Based on these results, I went ahead and added two more pounds of CYA to a nylon sock and it is presently in my skimmer. I'll add another sock with one more pound of CYA (three pounds total) tonight.
I am planning on adding a quart of MA tonight to bring the pH down in another cycle of acid and aeration per the articles here on the forum, and will probably also add a pint of 10% bleach, based on the pool calculator.
Any thoughts?
Lee
