Results 1 to 10 of 12
Thread: Pool is filled, now what do I do?
    Default Re: Pool is filled, now what do I do?
    Does it say copper anywhere on those trichlor tabs? If so, don't use them. Contrary to popular belief, it is copper that turns blonde hair green and not chlorine like people think. If you are going to use those tabs (once you make sure they definitely don't have copper in them), then they will add CYA as they add chlorine. But, after awhile when your CYA builds up to 45 or 50, you'll want to discontinue using them and only use bleach. If you do decide that you are going to use them, you won't want to put all that CYA in separately, though.
    Your other option is to not use them and just use bleach from the get go and add the CYA separately like I mentioned above. That is what I do. Your choice. Either way will work.
    Jun 2013
    Southwest Ohio
    I do not see copper anywhere on the container. It doesn't say what the other 1% ingredients are.
    Jun 2013
    Southwest Ohio
    Hi again!
    Tested with oto/red phenol this evening. Chlorine is less than .5 and pH is 7.8. Electrician coming this morning. What is the next step.
    Thank you!
    Get some bleach in there or your pool is gonna turn green! Add one jug of bleach by pouring it slowly around the perimeter of the pool as far from the sides of the pool as you can reach. Stir it around the best you can with a clean broom or oar or something. (Also, until you get some CYA in there, remember that you are gonna have to test and add bleach a couple of times a day to maintain a chlorine reading. Once the CYA dissolves, then you will be able to test and dose with bleach in the evenings only.)
    membership updated.
    To reiterate WaterMom's recommendations, ADD BLEACH NIGHTLY, till you get your program going. You do NOT want that pool to turn green.
    Pouring 3 gallons in tonight, and than 1 - 2 gallons every day after should keep you safe.
    Jun 2013
    Southwest Ohio
    Finally got the pump plugged in yesterday afternoon. Last night I hung 4 lbs cyanuric acid (in 2 socks) over the side of the pool by the water return jet and I also poured in 2 gallons of bleach. This morning the numbers are Cl = >5 and the pH = 7.6. My total alkalinity is still very high 270ppm. No hardness (calcium?) detected (water didn't turn red at all with the drops just kind of light yellowish). Cyanuric acid level = 30ppm. Now what do I do? The Aqua Smarte Mizermax Pacs say to let the chlorine level go down below 1 before inserting the pac. It was below 1 until I added bleach, so should I wait until it is back down and put in the pac or should I keep adding bleach? I will be using those pacs as the chlorine source. Also, we are getting ready to leave for vacation and will be gone for 10 days. I was hoping to have the chemicals figured out before we leave so I don't come home to a pond. Should I leave the pump running while we are gone (I assume so). I was thinking that the pump would run 24/7 all summer, but I've read where folks turn it off sometimes. Any suggestions there would be great. The pump has a low and a high setting. I have it on high right now to circulate all the bleach, CYA, etc. Should I leave it on low while we are gone? There will be someone here part of the time if something HAS to be done while we are gone, but they won't be swimming, just looking after the house and the cats.
    Thanks so much for getting this newbie started! When I tested the water this morning it was SO warm and the girls and I are just dying to take our first dip!!
    Ashley
    To go on vacation, given your situation:
    1. Insert your Aqua Smarte chlorine packs now -- don't wait for the chlorine to go down.
    2. Lower the pH to 7.2 -- your high TA will cause it to rise slowly.
    3. Purchase 15 gallons of plain 6% household bleach, and store it in a cool place accessible to your pool caretaker.
    4. Run your pump on low for 1 day, to make sure everything works OK, then turn it to high, and leave it there till ready to go.
    5. Before leaving, turn the pump to low, and the tablet feeder to a low setting.
    6. Instruct your pool caretaker to add 1/2 gallon of bleach every EVENING -- NOT morning!
    7. Instruct him/her to feel the pool surface under the water -- if it feels the slightest bit slimy, add a FULL GALLON more.
    That's it.
