Thread: Chlorine tabs vs chlorine bleach generic
    Jun 2013
    Washington
    Default Chlorine tabs vs chlorine bleach generic
    After reading Some of your posts I want to know if using chlorine in jugs from the store are better than using the pool store tablets?
    Default Re: Chlorine tabs vs chlorine bleach generic
    Many of us use bleach. It is cheap, readily available and adds the least amount of other things to the pool. It is all that I ever use in my pool.
    Welcome to the Pool Forum!
    Jun 2013
    Washington
    How do you know how much to use?
    It depends on the volume of your pool. Give us some info about the pool. Type of pool, volume, size of pump, type and size of filter. Also, tell us exactly what all products have been used in the pool, meaning ingredients and not just product names like 'shock.'
    Can you supply us with any water testing numbers and tell us what you used to get them?
    You need a good test kit. The one we recommend is the Taylor K-2006 or 2006C (same kit with larger bottles of reagents). You can't get it locally, but you can get it through the link in my signature below.
    Quote Originally Posted by Cahoonh View Post
    http://www.poolforum.com/pf2/showthr...18-bleach-calc
    Mar 2012
    Tennessee
    We will never use anything else but the BBB method for our pool. It has made maintaining a pool sooooo much easier. Again, this site has been fantastic.
    1 1/2hp Emerson 2speed pump, BBB
    27' round 19.3K gal AG Vinyl Liner pool; sand filter; pump: 24 hrs on low; Taylor K-2006 FAS-DPD Chlorine; utility water ; PF:6.9
    thanks for the attaboy!
  1. Chlorinator w/ tabs & liquid chlorine?
    By jsica in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-04-2013, 09:33 PM
  2. Baquacil to Chlorine (generic chemicals)
    By tbolton in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-11-2012, 10:04 PM
  3. Chlorine tabs: How many floaters recommended?
    By Pool daddy's in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2011, 05:32 PM
