Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 45
Thread: Pool problems on startup
    stma is offline Registered+ Thread Analyst stma 0
    Poconos, PA
    Default Re: Pool problems on startup
    Hey Ben:: I did receive the DE (for pools) today... I applied as per Carl's directions. In the event this does work, Should I see a difference in the cloudiness pretty quick ?
    michael3 is offline Registered+ Thread Analyst michael3 0
    May 2013
    Stma, I just got home with new sand and a 24 lb box of DE lol, pretty excited to get everything back together, of course there calling for severe storms here this afternoon. Maybe both our pools will clear at same time lol
    Quote Originally Posted by stma View Post
    No. Here's why:
    A sand filter filters in depth, capturing debris in the first 4 - 12" of the sand. If you think of each 1/2 layer of sand, then a 3 square foot filter (24" diameter) filtering with the top 6" of sand would have a total filter area of 3 sft x 6" x 2 layers/inch = 36 sq. ft of filter surface.
    By contrast, a DE filter works by filtering on the surface only.
    This is why a sand filter has an effective flow rate for good filtration of 15 gpm/sft, but a DE filter has a flow rate of 2 gpm/sft. Thus a 3 sft sand filter can handle a flow of 45 GPM, but a 3 sft DE filter can handle a flow of only 6 gpm!
    What happens when you add DE to say, an 18" sand filter, is that you convert a filter that can handle 25 gpm, to a filter that *should* handle only 3.5 gpm. It *will* handle more, but at the price of stopping up very, very quickly.
    I suppose in theory, if you fully coated a sand filter, and then backwashed it several times per day, you could clean up a mess like your quite quickly. But most people don't do that.
    ALSO . . . some of the particles in badly clouded pools seem to be too fine for even a DE filter to handle quickly -- it make take multiple passes through the filter to get everything.
    Poconos, PA
    I have the next few days off and have ZERO problem fully coating and backwashing.... Could you define "Coating" ?? I have 12 pounds of this stuff and the quicker I see bottom, the happier my life will be !!!
  6. #16
    Probably 3 oz by weight per square foot of sand surface. (1.8 sft for 18" filter; 3 sft for 24" filter)
  7. #17
    Poconos, PA
    Just thinking out loud here, I would need to "coat" after every back wash ??
  8. #18
    Poconos, PA
    @Ben, VERY much appreciate you sticking in here with me on this !! Quick question :: After 20 minutes of adding the DE, my pressure went up 2 pounds..... 40 minutes later (an hour after application) the PSI jumped 3 more pounds... Is more pounds a good thing and let it ride, or do I need to backwash and start again adding less DE ??
  9. #19
    I'd backwash at a 7 - 10 psi increase.
    You need to coat after every backwash, because the DE is flushed OUT of the filter during backwash.
  10. #20
    May 2013
    Hows your progress going stma? seems like it takes about 2/3 of a cup of DE to get 1-2 psi rise on my system. let it run all night and it has only risen about 5 psi. not sure if thats a good rise or if it should have climbed quicker lol, anyways I`m going to do like Ben suggested and wait till I get 7-10 increase then backwash and add more
  1. Crazy Cat Lady's Pool problems on startup
    By crazy cat lady in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-21-2013, 02:17 PM
  2. Vinyl pool startup
    By Bedwards01803 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-10-2013, 08:34 PM
  3. Pool startup problems.
    By Tander in forum Intex-type Pool Setup & Operations
    Last Post: 05-28-2012, 08:31 PM
  4. New Pool Startup
    By stuckpipe in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-06-2011, 09:23 PM
  5. New Pool Startup - Help
    By under_h2o in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-28-2006, 04:35 PM
