Results 1 to 10 of 45
Thread: Pool problems on startup
    stma is offline Registered+ Thread Analyst stma 0
    Poconos, PA
    Default Re: First test readings of season
    Glad to report Michael that the triple dose of Floc yesterday yielded absolutely ZERO results !! $$16 Bucks and The Green Fog continues... PLEASE post if you ever get things back in line and loose the cloud.. Love to know how you did it... BEN/WaterMom/Marie:::: any hint as to this never ending fog ??: Went the shocking route for a month already.... Few weeks back, Placed a container of Natures Chemistry Metal Free and the pool turned blue with 24 hrs...Starting shocking again assuming this would take care of the cloud...to no avail.. this also includes new sand and a skimmer sock to boot
    FC: 16.5
    CC: 0
    PH: 7.2
    ALK: 90
    CH: 30 (Vinyl liner)
    CYA: 65 ( I know) ! : >
    6800 gallon AG Vinyl
    michael3 is offline Registered+ Thread Analyst michael3 0
    May 2013
    Wow, was hopeful for ya. I'm even considered maybe partial drain and refill
    Poconos, PA
    Ben and Mom: Thanks as always ! Yes, this has been nothing short of a night mare this season.... Almost appears as a TDS issue that demands replacement of the water altogether.... Obviously not wanting to dump 6600 gallons down my driveway, and an alternative to your "Alternative Approach," Could i attempt the cup of DE through the skimmer? Or is that just a pipe dream at this point...?
    Quote Originally Posted by stma View Post
    I'm not sure it will solve the problem, but what have you got to lose if you try it?
    Adding DE to a Sand Filter
    Poconos, PA
    Thanks again Lisa...
  1. Crazy Cat Lady's Pool problems on startup
    By crazy cat lady in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-21-2013, 02:17 PM
  2. Vinyl pool startup
    By Bedwards01803 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-10-2013, 08:34 PM
  3. Pool startup problems.
    By Tander in forum Intex-type Pool Setup & Operations
    Last Post: 05-28-2012, 08:31 PM
  4. New Pool Startup
    By stuckpipe in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-06-2011, 09:23 PM
  5. New Pool Startup - Help
    By under_h2o in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-28-2006, 04:35 PM
