@Ben, VERY much appreciate you sticking in here with me on this !! Quick question :: After 20 minutes of adding the DE, my pressure went up 2 pounds..... 40 minutes later (an hour after application) the PSI jumped 3 more pounds... Is more pounds a good thing and let it ride, or do I need to backwash and start again adding less DE ??
, attempt the 4 cup dose atleast a few times today and see if you see a marked difference ( I know I did)...... just an fyi: it does take a bit longer to backwash.... i was/ and have been adding water throughout the process... But I think the water will be a freebie today based on the forecast...
