You definitely do not want to continue to use any form of stabilized chlorine. You do NOT want your CYA any higher. Your CH reading is fine at 275. Why not use use bleach? It won't add more calcium nor more CYA.
You also should consider getting a Taylor K-2006 or 2006C (link in my signature below) so you can test your own water. Pool store testing is often not very accurate.
