Thread: Trouble balancing pool
    Jul 2012
    TX
    Default Trouble balancing pool
    About 1 week ago pool was green. I have been running pump 24/7 ever since. I have also kept my chlorine level between 20 - 25 during that time. As of now the pool is blue, but cloudy. The part that is troubling is that all of last year my CYA level was around 80 - 90. Now it is a lot lower this year. I realize that it will drop some due to backwashing and re-filling, but according to the black dot test I am guessing CYA levels are around 40 - 50. But when I took a water sample in today to my local pool supply store they told me it was at 12.
    Should I be concerned? Would the high chlorine levels cause my test and their test to be off? What should I do. I was about ready to let my chlorine levels come back down since all the green is gone, but I am not sure now.
    Current readings:
    FC: 22
    CC: 0
    PH: 7.4
    Alk: 111
    CYA: Not sure?? I guess somewhere between 12 and 50.
    18' round 8.3K gal AG pool; Tablets, switching to Bleach; sand filter; 1.5 hp pump; 8hrs; K-2006; utility water; summer: ; winter: ; android phone; PF:15
    Default Re: Trouble balancing pool
    Trust your own CYA reading.
    Test your chlorine in the evening after the sun is off the pool. Test it again the next morning within one hour of sunrise. See how much chlorine you are losing overnight and report it. Keep running your pump 24/7.
  1. Balancing water in our new AG pool - want to use BBB method
    By TnVol in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-10-2013, 11:03 PM
  2. Help with balancing my water - which do I address first?
    By derekb41 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2012, 12:36 AM
  3. Re-balancing after switching to Chlorine
    By GeneNTN in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-06-2011, 02:48 PM
  4. balancing levels
    By purplegirl in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-04-2010, 12:16 PM
  5. No free chlorine, trouble balancing
    By sapphire in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2010, 07:48 PM
