Results 1 to 10 of 14
Thread: Installing new liner
    Jun 2013
    Alabama
    Default Re: Installing new liner
    Waste I would love to hear some tips from you on the liner install. I am making plans to build and put a pool in next year in AL.
    jilted is offline Registered+ Thread Analyst jilted 0
    Jun 2011
    Louisiana
    phew!
    26,500g inground vinyl liner (new liner installed June 2013)
    Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
    Compu Pool CPSC36 SWCG - Polaris 380 cleaner
    Jun 2011
    Louisiana
    Thanks!
    I'm happy that part is over. Hanging the new liner is easy with 6 people. The tear out and cleanup was the hard part.
    I did end up with 3 or 4 small wrinkles that won't come out but I think its partially because of that little leak in the poolcrete I do have some water behind there that still needs sucking out.
    But having no experience with this, I consider it 100% success!
  1. Installing a skimmer on a new Liner
    By avgirl in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2012, 12:16 PM
  2. Installing New IG Liner Questions
    By JJNMRSDAD in forum In-Ground Pool Construction and Repair
    Last Post: 07-09-2011, 08:56 PM
  3. Re-Installing Liner
    By dru0636 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2010, 08:37 PM
  4. Installing New Liner
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 02-25-2007, 10:13 AM
  5. installing vinyl liner
    By bazman in forum Above-Ground Pool Construction & Repair
    Last Post: 07-12-2006, 05:42 PM
