Thread: chlorine and solar covers
    Bosch232 is offline Registered+ Thread Analyst Bosch232 0
    Aug 2012
    Nebraska
    Default Re: chlorine and solar covers
    Thanks! The conversion to chlorine from $oft $wim was the best thing I did. WAY cheaper, and BBB has been super easy to maintain so far. This forum taught me everything.
    16x32 Oval AG vinyl pool; Media Master sand filter; 1.5 hp 1 speed pump; 10 hrs; Rural utility water; Taylor K-2006
    Wisconsin
    Would a blue or semi opaque cover slow chlorine loss more than a clear one?
    Yes, the more opaque the cover (especially to UV), the lower chlorine loss from sunlight. The downside is that you'll also get less heating of the water from sunlight so may not get the pool water temperature to be much hotter than the average day/night temperature if it's too opaque. If it's more opaque, then a darker cover plus water circulation can still heat the pool somewhat, but a mostly clear bubble-type cover heats the best (though doesn't protect chlorine loss very much).
