Re: Difference in Water Analysis
You say "some people have had luck with using a CuLater". Does not appear real positive .
Couple of questions on Culater I see they come in different gpm and all for 20000 gals .So Im at 23000 gals so do I just use one or go with two ? What gpm?
I am just finishing day two of the Metal Bucket Test. So far both buckets are clear and no visible color .Chlorine as expected was high today .Will report in three days .
If you look at my posting you can see I have a stain that occurs every 7 days and then with treatment of Metal Out it fades . From what I read it has to be a Iron stain to be erased with the Vitamen C or am I incorrect ?
Of the Metal chemicals do you have a recommendation between Jacks Magic and Natural Chemestry or another
16x32 rectangle 23K gal IG pool; trichlor feeder; Hayward HE-65 DE filter; Hayward 1.5 pump; 12hrs; Taylor Kit - can test FC-CC-CYA-ALK-Hardness; utility water;; PF:5.2
Been on bleach since 2012
