Thread: ph and alk balance
    May 2011
    Reading, PA
    Default Re: ph and alk balance
    K I won't add anything. Just thought the alk should be a min of 80
    Thank you for your feedback!
    In ground, outdoor, vinyl liner, 22,000 gallons w/Aqua Genie skimmer installed in 2008, 1 HP Hayward 2-speed Super Pump and Hayward pro series high rate S244T both installed 2016
    May 2013
    Concord,ca
    If ch and ph are good wont the rest fall in line?
    Quote Originally Posted by dansdad View Post
    Not necessarily. But you do need to start with those two, BEFORE you try to fix other things.
