Results 1 to 8 of 8
Thread: Salt or chlorine...Permasalt????
    Jun 2013
    North Carolina
    Default Salt or chlorine...Permasalt????
    So I sold My boat :-( and putting in an AG pool for the family. Well for my wife, haha. I have shopped around and yesterday was told about this permasalt system which I had never heard of. I had heard of salt water systems vs chlorine but perma salt was new to me. Well I have been reading post after post about this not actually sanitizing the pool. I am honestly now torn between using salt period or using chlorine. I have seen family members with pools fight green cloudy pools for years using chlorine systems where neighbors of mine use salt and have beautiful clear water all the time. I am thoroughly confused as to what to do. I want the simplest most cost effective system to use if there is such a thing. Thanks for any input and or suggestions
    Largo, Florida
    Default Re: Salt or chlorine...Permasalt????
    Welcome to the forum, and congratulations on having experienced both of the happiest days of a boat owners life! Although honestly when I sold mine, I wasn't all that happy about it- but I digress. Salt pools are chlorine pools. Here's an excerpt from poolsolutions.com. I highly recommend some reading the guides there. Here's a quote:
    Swimming Pool Salt Water Chlorine Generator FAQ
    What is a salt water system?
    A salt water system or “salt water chlorine generator” (SWCG, SWG) is used to replace traditional chlorine with chlorine produced from salt in the pool water.
    How does it work?
    Salt, or sodium chloride, dissolves in water separating into sodium (ions) and chloride (ions). By passing a low voltage electrical current between special metal and through the water, the SWCG then converts the chloride into chlorine in a process called electrolysis.
    The newly created chlorine creates a chlorine residual, and is available to sanitize the pool. When it is used up, it changes back to chloride, and allowing the process to start over again.
    So a pool with an SWCG is not chlorine free?
    Correct! An SWCG is just another way of adding chlorine to your pool. It's a good way of doing so, but the end result is still a chlorinated pool.
    I'm not sure what "perma salt" is but most likely it is simply a brand name for a salt system. The salt in a SWCG system is never used up so technically all salt pools are permanently salt pools. Unless you replace the water.
    Largo, Florida
    I looked up the Perma Salt system. It is NOT just a swcg. It adds copper and silver to your water along with the chlorine generated. Personally, I'd avoid the product. Copper turns hair green, stains pools and is only marginally effective as a sanitizing agent.
    Quote Originally Posted by wwooten View Post
    membership upgraded.
    Just wanted to be sure you are clear on the fact that 'salt' -- using a SWCG (Salt Water Chlorine Generator) -- is just a METHOD of adding chlorine. There's a lot of deceptive SWCG marketing out there that obscures that fact.
    Jun 2013
    North Carolina
    Thanks so much everyone. I did in fact realize that the salt system generated chlorine. Didn't know exactly how until now. As for the perma salt system, I have seen NOTHING positive about this system so I will avoid it for sure. I do want a more low maintenance system as we travel to the family lake house a bit as well so I believe a salt system is gonna fit my needs best. I am sure you'll hear more from me in the near future as I try to figure all this new stuff out.
    Don't go with salt until you have checked, and verified that all your pool equipment is salt compatible. The saline levels are fairly low (~4,000 ppm vs ~35,000 for ocean water), but high enough to cause increased corrosion.
    Jun 2013
    North Carolina
    Ok thanks.. Will definitely make sure of that. I have one more place to shop, but so far everyone says their entire pool and systems are compatible as this is the most popular system around here. You folks have been a big help. I truly appreciate it and will be ordering my test kit through the links!! Thanks again
    Thanks.
    UPDATE: the PermaSalt info is available through this link: http://pool9.net/permasalt/
  1. Anyone using salt w/o SWG in their chlorine pool?
    By Rangeball in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 02-03-2011, 10:04 AM
  2. Switching from Chlorine to Salt
    By kmmlangston in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-05-2010, 09:59 PM
  3. chlorine and salt w/o swg
    By fullhouse in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-26-2006, 06:35 PM
