Thread: Adding new Pool in Home
    Jun 2013
    Nebraska
    Default Adding new Pool in Home
    Hello!, Im new to this Forum and am needing tome In put on your advise as to the Depth of a Pool. The size we are looking for is a 15 ft by 32 Long. It will be a Indoor Pool. I was wondering If anyone could give me some pictures for this size of Pool and any suggestions. It Is going to be a fiberglass Pool also. Thanks and looking forward in hearing back with any input you or whoever may have. Also What is better? Clorinated water system or salt water system?
    Voosch
    PS: Also need to ask what depth does a person need for Diving? Thanks Voosch
    Default Re: Adding new Pool in Home
    updated membership.
    Salt systems (using SWCG) *are* chlorine systems. An SWCG simply turns you into a low volume manufacturer of chlorine, from salt in your pool's water.
    By most standards, a 32' pool is very marginal for diving. I'm not sure what current specs are -- but unless you make most of the pool over 8' deep, a careless but athletic teenage boy can easily break his neck -- speaking literally, not figuratively -- on such a pool.
    Jun 2013
    Nebraska
    Thank You for your reply back and your answering my Questions. Voosch
