http://www.poolcalculator.com/
Don't dump the prescribed amount in all at once. Add some, wait an hour or so, then test again.
Good Luck!
Good Luck!
JnKY
30' Round 24K* gal AG Vinyl Pool; 5.25% Bleach; Hayward IS210T Sand Filter; Hayward SP1580 1 speed pump; Utility Water; Taylor K-2006C Test Kit
Here is a calculator that we like better:
http://www.poolforum.com/zxq/BleachCalc262.exe
It is more than just a bleach calculator. If you click on the drop down menu in the upper left-hand corner, there are other calcs.
However, Jason is right that you add a smaller amount than you think you need, test, add more if needed. The exception to this is bleach. When adding bleach, you need to add enough to get to the chlorine level that will be high enough to sanitize your pool.
