Thread: Replacing old reagents in Taylor test kit
    jilted is offline Registered+ Thread Analyst jilted 0
    Jun 2011
    Louisiana
    Default Replacing old reagents in Taylor test kit
    Do they all need replacing every year or does storing them in a mild dark location make a difference?
    I need to order some CYA test reagent i am completely out of that.
    Does the DPD powder go bad?
    When you start doing the math, if a majority of them need replacing, it almost makes more sense to order a new kit!
    Thanks!
    26,500g inground vinyl liner (new liner installed June 2013)
    Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
    Compu Pool CPSC36 SWCG - Polaris 380 cleaner
    Default Re: Replacing old reagents in Taylor test kit
    You do not need to replace every year. And, you are right. Storing them in a cool, dark place does help to prolong the life. DPD eventually does go bad. You will be able to tell. It will get gray and clumpy.
  1. Taylor Reagents in Canada
    By snapperhead in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-26-2011, 01:32 PM
  2. Where to buy new reagents for Taylor K-2006?
    By blessedbeingmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-29-2010, 01:06 PM
  3. Shelf Life of test kit reagents
    By SandyDittmer in forum DPD-FAS based testing
    Last Post: 06-24-2010, 09:22 AM
  4. DPD reagents or buy another test kit
    By nthach in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2010, 09:51 AM
  5. Storing and re-using Taylor's reagents
    By Water_man in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 10-12-2008, 12:02 PM
